club-home
7 products
Direct
Immersive Messenger
Watch Party
XenPing
XenSpotlight
XenStaff
XenStreak
Hi Gwendal,
Lucent really looks very promising, impressed. I’m considering it for my board, and I have a few questions about compatibility and one layout suggestion.
Are Lucent’s page transitions purely visual effects around normal page loads, or do they replace page content without a full reload? Can they be disabled independently of the other animations? I’m particularly interested in how they interact with Direct and third-party JavaScript components.
Are there any known incompatibilities? If a third-party add-on works correctly with the default XenForo style but has a problem in Lucent, does your support cover investigating and fixing the Lucent side of that issue?
One layout option that would be particularly useful for me is built-in vertical navigation on desktop.
I currently use [cXF] Vertical Navigation because the board has several main sections more that 15, not just forums. Thus in classic navigations line are looks uncomfortable.
Would you consider offering a left-hand navigation sidebar as an optional Lucent layout, alongside the existing header layouts?
Ideally, it would:
Would this fit Lucent’s roadmap? If it is not planned, could you confirm whether Lucent can work with [cXF] Vertical Navigation?
Thanks for your time!
Ideally, it would:
- Use XenForo’s existing public navigation, including child items and permission-based visibility.
- Support an expanded sidebar with labels and a compact, icon-only mode.
- Be selectable by the administrator in Lucent’s style properties.
- Keep Lucent’s existing mobile drawer and bottom navigation on phones.
